Thread: Power Steering
Old 08-24-2011, 12:29 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by imfastrnu2 View Post
Thanks for all the suggestions. I think I'm going with the March brackets and pulleys so i know everything will work together, plus I get the advantage of having serpentine belts. I'll check on the Saginaw pump mentioned in the HAMB forum, Napa part #NSP 816795. Napa does carry this pump and if it's a lower psi then it should work well with the Mustang II rack
careful that pumps applic is a F-150.....not a rack type of PS.
the granada\fairmont is for the rack type so the fittings are more compatible.
from what i found is there are two types of pumps the saginaw and the trw.
the trw is what most people call the ford pump. all the saginaw pumps are not GM ford used them too but this application was not for a rack type of PS so the pressures are higher. a valving kit will probably still be needed.
Fred B
