Old 08-25-2011, 03:28 AM
stumpeater's Avatar
stumpeater stumpeater is offline
Cobra Make, Engine: Harrison, VE L98 + T56
Hi Mike, when I built my stumpeater, the 3mm steel (80 litre) hydraulic oil tank I made had a similar bracket to yours mounted on the side, and that cracked along the top weld and had to be reinforced with a big plate. It does cop quite a lot of low frequency vibration, but also would have been damped by the oil. I notice the Brown Davis tank has the brackets going from top to bottom which would stop any flex in the walls. My two bobs worth. Not being picky just trying to help, it would be a pain to repair the tank after it has had fuel in it.
Life is what happens to you while you're busy making other plans...JWL
