Old 08-25-2011, 05:59 AM
ted ted is offline
Regarding the clicking noise, check your valve springs for shiny wear spots on the inner dampers. There's a good chance the noise you're hearing is due to the inner spring working against the outer spring. In most instances, this is due to 'crooked' or 'leaned over' outer springs.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
