  #38 (permalink)
Old 08-25-2011, 08:00 AM
Mando's Avatar
Mando Mando is offline
Hi Mike, Stumpeater hits the nail on the head with his comment that the plates welded to the tank "might" need to be much bigger to spread the load. I don't think the rubber mounts at the size they are at the moment will make any difference because by the time you tighten up the bolts enough to stop the tank from bouncing the rubbers might as well be a stack of metal washers. That's my 2 cents worth!
Regards.
Mando
