Old 08-25-2011, 03:27 PM
xb-60's Avatar
xb-60 xb-60 is offline
Left side of tank you see is hooked to a breather plate at the back of the intake and a breather tube to the top of the trans. Right side of the tank has a high and low tube. Low one routes to the oil pan for condensed oil, high one connects to a draft tube for vapors that goes out under the car. This is illegal on modern engines as it caused an oil slick on the road (or track). People usually plumb it into a PCV instead of the draft tube.
So if vapours still go out under the car, what are you gaining with a puke tank?
Another question... if the gearbox isn't vented to a puke tank, does the gearbox build up pressure and push oil out past the seals?
Glen
