Old 08-25-2011, 09:57 PM
400TT's Avatar
400TT 400TT is offline
Originally Posted by sevenohms View Post
By ADR i don't think this is ok. I'd be looking at doing something like fitting a stop to the seat track rail. A bolt through the rail might be effective at limiting the rearwards movement to pass the requirement.
I'm pretty confident 20mm high-density foam will be acceptable. QLD Trans etc accept it when roll bars are that close, can't see why Regency would not. But it's best if Mando checks to confirm, I'm surprised they did not suggest it.
I'm interested to hear why you think it would be a problem. As long as it is attached securely, does not block rear visability etc, it will be fine in my opinion.
Problem with moving the seat forward is that 60mm is just too far in my opinion to look and act normal. With seat moved that far forward, I wouldn't be able to even get in and Mando definitely wouldn't be able to as he is a bit larger than me.
www.absolutepace.com
