Old 08-27-2011, 11:46 PM
stephen low's Avatar
stephen low stephen low is offline
Default Second E303 cam available
Folks
As a follow on to my final message in my other thread asking if there was someone with an E303 cam they didn't want, I found a fellow with two unwanted E303 cams.
I've bought the cam he was going to use in his cobra build but he will be stroking the motor. His is an unfinished original replica Bongalis kit, chassis No. 11 he tells me, so he has had the car some time.
The cam is coded M-6250-E303 so is the correct Motorsport cam.
The second cam available is the same and is out of his brother's GT40 build and had only done about 500km when that motor was torn down for a stroker rebuild.
If anyone is after a cheap E303 cam send me a PM and I'll put you in contact with this fellow.
Steve
slowy
