Old 08-29-2011, 10:19 AM
tgitchel tgitchel is offline
Cobra Make, Engine: ERA #776, 445 FE
Originally Posted by elmariachi View Post
Black wires from Taylor with the labeling removed using CRC brake cleaner. Separators available here from Mustangs Unlimited.
Thanks, I got the wire separators from the link you provided. Now if I can find a good source for a black distributor cap, I might work up the energy to replace all the plug wires too. I think that would look the best without any bright colors on the engine itself.
Also, I got the taller K&N filter and am working on a custom drop base so it will fit under the hood. Once all that is done and the temps drop a bit, it's off to the dyno for a final tune.
