  #29 (permalink)
Old 08-30-2011, 09:54 PM
Three Peaks Three Peaks is offline
Larry,
Is your 115V unit set up for a spool gun? Most of the 115V units I have looked at, including mine, don't have the electrical connections for the spool gun control for the welder unit.
You may need to go to a larger unit to get the spool gun compatibility. I've been looking at the 180/210 amp units partly for this reason.
However, I've used the aluminum wire in my 115V Miller 130 and it worked pretty well as long as I kept my hose pretty straight and everything was good and clean, including my tips.
Good luck with your practice, it takes a bit to learn the technique.....
Bob
