Old 09-03-2011, 10:46 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Any chance you found the loss of vac. since your last post? I know you needed to verify timing still so maybe... A pyrometer is available from Harbor Freight for around 15 bucks on the lower end of prices. I bought one and it tracks with my higher quality and priced unit just limited on options and bling. The pyrometer should show a temp difference on the lean cylinder/s if manifold or gasket is leaking.
Were you able to kill the engine at idle by closing the idle mixture screws? Close one side at a time but either side should stop the engine from idle.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
