Old 09-05-2011, 07:36 PM
Dwight's Avatar
Dwight Dwight is offline
Smile Accel oil filled coil
Accel's installation instructions suggest you mount their oil filled coil vertical. They do not tell you if you mount it horizontal or on a non vertical position the air bubble inside will expose the coil and burn it up. If you call and ask them about it they will tell you it "should" be mounted vertical or it will damage the coil.
Did you have an oil fill Accel coil?
Dwight
