Old 09-05-2011, 08:30 PM
Keithc8 Keithc8 is offline
We pretty much use the T&D stuff and then forget it. I have not used any of the other stuff that is out there not to say that it will not work but the price has always scared me. I assume that they must be made over seas and there are other things that we use that is made over seas as well that we have had no problem with.
It is hard to find a low cost rocker arm assembly for the FE but these that brent mentions might work fine in most cases, just have not tried them.
I have some brand new original Ford adjustable stock style rocker arm assemblys and they work fine on most hydraulic and solid flat tappet stuff if the spring pressure is not over about 350lbs. I also have some of these with the hardened shafts that have very little time on them. I would take 250.00 for either set and they would work fine for you as well.
Thanks, Keith
Keith C
