Thread: Spring Rates
Old 09-07-2011, 06:37 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
OK Lou, you didn't tell us why the change. What happened to the 225 lb. springs and why did you change your mind. I am thinking there is no way the 185 lb. springs are going to work with mine. I think the rear looks good at 28"-28 1/4" to the rear fender lip, but that just gives you about one inch before you hit the bump stop. When I set in the car with my 240 lbs. the car drops another 3/4", so either I jack these light springs up or go to a higher rate spring. Where did the 225 lb. springs end up as far as threads for adjustment.
Wayne
