Old 09-08-2011, 09:17 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Originally Posted by Bobcat View Post
I can`t run any spacer as I run the tallest filter element ( almost 3" ) I can get and also a drop base filter housing ( 14 " filter ) . I have about 1/8" clearance on the passenger side ... remember , your engine is offset to the right on a 427 . The engine wants to torque to the right anyway ..... I do get some contact on the passenger side , but only if I go WOT quickly ( on the front and back straight at VIR ) , but it`s minimal . You can reduce your filter element height , and lose some power ( probab;y won`t notice it ) and do ERA`s motor mount mod to the driver side mount to reduce motor torqueing .
Try putting some clay around the air cleaner lid , close the hood , open it and measure what it was squished down to .
Bob
Did the clay already, but I didn't know about the offset, thank you.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
