Thread: 17 inch wheel
Old 09-09-2011, 03:00 PM
Tulsa cobra Tulsa cobra is offline
Will do and thank you very much.
Question, my hub has 5 hex bolts that protrude that line up with 5 holes in the tire, is that considered a 5 pin tire.
The confusion is that I have a boat that has a 2 pin prop, basically on the prop shaft there are two pins that extrude from it and they line up in the hub of the prop, that has two slits in it, holding the prop in place, so I consider that a pin.
I envision a 5 or 6 pin tire, having a similar pin sticking up that corresponds to notches in the hub portion, though this is probably incorrect.
Thank you again for all of your time and help.
