Old 09-10-2011, 05:15 AM
KirkV KirkV is offline
Cobra Make, Engine: Superformance #678
Funfer2 All I could afford right now was the springs so I put some 225 lb hypercoils on the existing shocks and will replace the shocks with qa-1's when the funds come available, Like after I sell the over and under browning lightning sporting clays gun I do not use LOL.
I do not understand replacing the shock with the heim you have pictured though? You can just adjust the coilover to get the lift you want correct? If the shock was replaced and the heim left in the body would be rigid to the frame.
Unless you are adjusting height with the heim for the scale weight and then putting the shock back in and doing it again? Sorry just a newbe here still learning.
