Thread: 351 Distributor
Old 09-11-2011, 06:36 AM
wolf k's Avatar
wolf k wolf k is offline
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
I am pretty sure the dimensions are the same on the two distributors in regards to gears and distance to clamping surface. The dimension of 4.035 is the same on 302/351 distributors and gear outside dimension is same on both. 302 gear will mesh with your cam. So your issue would be oil pump drive as stated by mreid and interference with intake manifold.
