  #23 (permalink)
Old 09-11-2011, 08:45 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
OK--try this on for size---The Cobra has a lot of room in front of the engine for mounting a super charger---As for turbos---you will probably lose the side exhaust, you are going to add a lot of heat to the under hood area of a vehicle that is severely heat challanged--you will be dragging around a lot of crap that will only become effective way above the range that you can drive on the street, and nowhere will you find an organization with rules/specs for what your doing--
If you want turbos, put a 4 cylinder in it with a system that will give you a pathway to increase and upgrade the power level as you gain ability(tuning the complete car as well as driving ability) and always wear a full driving suit and helmut, gloves,boots,etc, along with a full cage_____
