Old 09-11-2011, 05:53 PM
PowerSurge PowerSurge is offline
Exclamation Help Needed on Power Window Switch
Has any of you run into a Driver's Window Switch that works the Driver's side fine, but will not operate the Passenger front or rear windows? In trying the Passenger side switch, the passenger window still fails to operate. (?) I'm the new Owner of this Convertible and I didn't get an Owner's Manual with it. I did look at a Haynes Manual and saw that it not only has a circuit breaker as well as a fuse. It also stated the fuse box was under the Drivers side as well as a fuse block under the hood. The fuses were fine under the hood, but I couldn't find a fuse box there...the DLC for reading the ECM codes and what not, but where is this "ghost" fusebox live?
Any and all help to facilitate this repair would be greatly appreciated.
Respectfully Submitted,
From ~The Twilight Zone~
~Power Surge~
