Old 09-14-2011, 01:18 AM
tkb289's Avatar
tkb289 tkb289 is offline
If I can jump in here for a few quick questions ...
Originally Posted by Bobcat View Post
... do ERA`s motor mount mod to the driver side mount to reduce motor torqueing ...
Bob
Bob ... what is the ERA motor mount mod ?
To All ...
- Assuming new rubber motor mounts that are properly installed, is there any rule of thumb estimate as to how far a motor will typically move side to side (torque over) under load at WOT ?
- If looking at the air cleaner from the font of the car, with 12 o'clock nearest the firewall and 6 o'clock nearest the radiator, which position on the edge of the air cleaner would tend to hit?
- Any consensus as to a best practice dimension for air cleaner to hood clearance ? I am thinking 1/2" clearance should be enough room to avoid rubbing for most cases, short of having a broken or loose motor mount. Too much ... too little ... Any thoughts?
... Thanks !
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
