Thread: SPF Speedo Fix
Old 09-14-2011, 09:41 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by SPF1061 View Post
I have a question. When replacing the SPF speedo cable with the napa replacment# 615 1644, is it necessary to lube the napa cable? If so, what to use and exactly how do you do it? TIA!
Mine came sealed with cable installed (pre greased). The only problem that I ran into, was that the crimp on the transmission end of cable dripped a bit. I ending up cleaning it thoroughly and sealing it with some red permatex, which fixed the drip.
Doug
