  #22 (permalink)
Old 09-15-2011, 03:32 PM
Dually Dually is offline
Default SBF specs
Displacement: 347CI
Block Type: Ford Boss 8.2 deck
Compression Ratio: 10:1 +/-
Caburetor Size/EFI: 750 Barry Grant RR Demon DP
Peak Crank HP @ RPM: 482@6300 (avg 384 from 3500 - 6600)
Peak Torque @ RPM: 430@5300 (avg 414 from 3500 - 6200)
Other: Anything else "trick" you have above and beyond a street performance motor.
Basically took a new Ford Racing 450hp 347 and dropped at my engine builders shop. Complete blue print, about 5 hrs short turn radius work on heads, port match and cleanup. True decks to give comp a slight bump. Reassembled with all original parts with exception of Melling Select pump, MLS head gaskets and Aviaid GT40 pan. Very mild tune running right at 12a/f with 35 degrees timing all in by 3200 rpms. Water temp 178, oil temp 190. No doubt we could have gotten to 500hp if we leaned on it a little more.
5000 trouble free and fun miles since build completed in July 2010.
Currently building 363ci using basically same parts with exception of h-beam rods, internal balance, higher quality pistons, 11:1 cr and mid level solid roller. Hoping for 550-575hp with a usable RPM range up to 7200. Considering new Edelbrock XT FI for this engine.
High revving small blocks are a blast in these cars.
