Old 09-16-2011, 04:14 AM
Tommy's Avatar
Tommy Tommy is offline
This is a guess because I'm not familiar with the SPF setup. But as you say there is a starter relay, this is what I would expect.
  • There should be a constant +12v going to the ignition switch
  • When the switch is in the START position, there should be +12v going to the relay
  • There should be a larger +12v wire also going to the relay
  • When the wire from the ignition switch to the relay is energized, it should close a switch in the relay allowing +12v to flow from the larger wire on to the starter
  • When the starter receives +12v from the relay (or from a jumper cable if you want to test the starter), it should crank
Starters need a lot more current to work than gauges. A poor battery cable connection can allow enough current flow to operate small things, but not the starter. Check both ends of the positive and negative cables for good connections.
Tommy
Previously owned EM Cobra
