Old 09-22-2011, 07:13 PM
Joey.S Joey.S is offline
Cobra Make, Engine: SP
You may have air trapped in the master cylinder.
You should be reverse bleeding, empty the reservoir and use a pressure bleeder hook it up to the slave cylinder bleeder screw, with the bleeder screw open a little force the fluid in from the slave cylinder into the master cylinder.
This has always worked for me on this type of setup.
