09-23-2011, 11:07 AM
IL
Cobra Make, Engine: ERA 454 S.O.
Originally Posted by jhv48
Pman, if your bleeder valve is on the top of the slave cylinder, like most SPF slaves are, the gravity method works fine. I Do it on mine twice a year and it has been recommended in other threads on this forum. However, if you want to make the job more costly and complicated, then by all means buy the equipment and do reverse bleeding. They all accomplish the same thing.
It does NOT work if you have air in the master cylinder, period. Tried it many times, I wish it was that simple.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
