Old 09-24-2011, 03:55 PM
patrickt patrickt is offline
Originally Posted by Jeff Frigo View Post
I had the dash down the other day. I now have parking lights, high beam, but no low beam. I am not good at using wire diagrams. All three wires are attached to the switch. Fuse #7 is good.
Jeff
What about Fuse #8? Check that for the low beams. If fuses 7 and 8 are good, then it pretty much has to be either the dimmer relay, the dimmer switch, or a connection between them. Try wiggling the connections and plicking the relay with your finger while you simultaneously hit the dimmer switch with the car ON. If all of that fails, I would replace the dimmer relay with VW Part # 111 941 583.
