Old 09-24-2011, 06:04 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
You probably bumped the relay. Grab the wires on the relay and wiggle them around a little bit. Your low beams will likely come back. I have the same problem with mine. I should probably just replace the relay, as that would be easier than reaching under the dash when the lights go out, but that is down on the list. And besides, I drive in daylight most of the time anyway.
Replica is not a dirty word.
