Old 09-26-2011, 04:01 AM
Default Switch to Hydro boost
Tin -man First name would be nice. Switch to a hydro boost setup. You can find them in some of the Rod mag's. You already have the PS system, it's easy to swap over the rest. If you want better brakes this is the way to go. The only thing is to add a P/S cooler under the front of the car on the radiator support to help control fluid temps. I run a P/S system with a Sweet rack. Works great, like you bad shoulder from baseball. No 90 mph any more. Lucky if I can thrown it 20'. Don't raise arm over head either. Anyway If you want more info, goggle it or I will get the people to talk to you. It's a bolt in system. The brakes will put you through the windshield in the beginning. You don't need a heavy foot. 1,400 -2,000 psi of pressure the system uses and this make the brakes stop quick. You might need a pedal stop under the dash. The pedal travel is only about 2". Just a thought. You built a car the way you need it to address you needs. It's just as fast as and 5 or 6 speed. I do have a ashtray in my car, and the other half quit smoking. Rick L.
