Thread: 408W or 427W
Old 09-26-2011, 10:17 AM
Dana E. Dana E. is offline
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
For the amount of horsepower that you're wanting, I really see no reason to spend the extra $2000-2500 for the Dart based engine. The block is more expensive right off the bat and the forged SVO crankshafts are more expensive than what you could use on a 408.
Good 351 blocks are hard to find in my area. Roller block motors last about one day, when they arrive, in the wrecking yards here. The going rate is $750 for a complete motor. If you're lucky, it'll clean up with a .030 bore. By the time you add in machine work on the factory block, I can upgrade and machine a Dart block for well under a grand.
somethings to think about, the shp block will put an additional 40# on the nose.
It looks like it's about 30# heavier.
If you do decide to go with the Dart based engine, I wouldn't stop at a 4.000" stroke, I would go with a 4.100" or 4.250" stroke for 445 or 460 cubic inches.
I like your thinking. I had thought about a 438, but I don't have enough intake or exhaust for a high HP 460 cubic inch motor.
