Old 09-26-2011, 11:26 AM
grybrd123 grybrd123 is offline
Cobra Make, Engine: N/A
Default Vacuum advance
Hi:
What kind of distributor do you have?
Is it both mechanical and vacuum advance?
If it is both, you must disconnect and plug the vacuum line to the carburetor to set the timing properly. After you have set the mechanical advance, you can connect the vacuum advance.
grybrd123
