Old 09-26-2011, 06:07 PM
eschaider's Avatar
Originally Posted by Ant View Post
I am looking at buying Petersons new remote oil filter mount this has a oil primer incorporated which an electric drill can be used on the drive spud, for those who want to prime their engines. ...
...filters come in either Ford 3/4"-16 thread or GM13/16"-16 threads ... would it be worth going to the slightly larger filter thread ...
There is a big advantage to using the NASCAR 1-1/2" diameter nipple (12 or 16 threads per inch) filters. Interestingly that is what Peterson first made those remotes for. Use a WIX 50003R or 50007R filter. Click here => Wix Filters. Or use the 57222R for larger capacity filtration.
There is also a non NASCAR WIX filter w/o the internal by-pass if that's what you want. Although it uses a different size mounting thread (1-1/8" x 16) Check out the flow differences in the T-10 and T-71 filter material. You will be impressed.
Ed
