Old 09-27-2011, 07:19 PM
olddog olddog is offline
Pull breather cap and look into hole with a light. If you see rocker arms, there is no baffle, and that could be the only problem.
If you see a baffle, I would think there is some serious blow by or perhaps the drain back wholes are blocked and oil is filling the entire valve cover at higher rpm.
