Thread: 351 Distributor
Old 09-28-2011, 04:28 AM
Ant Ant is offline
Default 351 Distributor
I contacted ICE and Cleveland dizzy on the way same shaft as Windsor with the correct steel gear for my flat tappet cam, he mentioned there is a chance of spark scatter due to not having an oil pump connected to the dist and backlash in the gears could become more of a problem as the oil pump acts like a damper, this may only happen in 1 out of 10 and if that happens a crank trigger would be a solution. I dynoed my engine with an MSD8578 Dist and the timing was very stable.
Better to get to work and finish the interior, build a new IRS and I have an intake system to design so heaps to do before the engine makes another noise.
A J. Newton
The 1960's rocked!
