Old 09-28-2011, 06:27 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
check the valve covers for the baffle.
Then you can determine if you have a bigger problem. Depending on the valve covers used and the rocker arms sometimes the baffles are removed to gain extra clearance.
This is typically found in the cast aluminum covers. I dont believe the pentroof covers have this issue.
The oil will find its way out of the beather leaking the oil. This is common.
