Old 09-29-2011, 11:32 AM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
[quote=got snake?;1153898]Jimbo!!! Sorry hear about the slave issue again QUOTE]
Sid - that post is from 2009, My car has been fine for the last 2 years (if you don't count the other things I have fixed like a leaky differential, transmission upgrade from bent shift rods, cracked side pipe that had to be welded, seized knock off, loose half shaft bolts, loose tach, front end alignment, blown fuses, broken trunk latch, loose valve covers, new tires front and rear, broken front wing window, loose spring on the LeMans gas cap, broken baffle in side pipe etc...) typical maintenance stuff, particularly when you race the car. Better said, my slave cylinder has been fine for two years!
1/4 mile 11.92@115.6 and 60ft 1.632
