Old 10-01-2011, 02:49 AM
tin-man's Avatar
tin-man tin-man is offline
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by Car Nut View Post
Apparently you have a vacuum pump which supplies sufficent vacuum to a vacuum operated power brake booster.
They make noise, that's normal.
Seems you called it correctly, I have been informed what I have is a vacuum pump to give the brake booster vacuum. Being the case then the noise I should get used to, right?
Cheers, John AKA, tin-man
Be well, drive fast, live long
