Old 10-02-2011, 09:07 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
It's been colder in the Windy City. You're probably idling it a little longer in the garage before you pull it out, and then again when you drive it back in, and don't even know it. Now, if you say the exhaust, while idling in the garage, is stinging your eyes, and it never used to do that before, then it's time to adjust the carb. Of course, it's probably not good to just sit there in the garage while your Cobra is idling and you just breathe the exhaust in. Hmmmm, maybe that's my problem....
Patrickt:
I had all of the idle mixtyre screws set at 1-1/2 turns out. I re-checked them tonight and maxed out the rpm. Believe it or not I went in a 1/2 turn with three of the four screw to to get max rpm. Go figure, the smell is almost not there any more. I figured qnything less than 1 1/2 turns would be too lean. Still runs and idles great.
Sometimes you just need to go back to basics.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
