Old 10-04-2011, 06:57 PM
elmariachi elmariachi is offline
Originally Posted by Bobcat View Post
Flygirl ... good link that Dwight gave you , but be advised that it applies only if you do WOT runs and then shut off clean . However , it gives you enough that you can get in the ballpark and is a great primer on plug reading in general .
Yes but, generally speaking, all the same things apply. Toasty tan is the optimum color, very slight soot on the base ring, and the annealing midway on the ground strap. I bought Don Gould's tuning guide here and it really helped me learn a lot about how all this works. Spark plugs are a periscope into an engine and if you learn this stuff and the basics of how a carb works, you can really get your engine purring.
