Old 10-04-2011, 09:51 PM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Originally Posted by Murky781 View Post
wipers need power after the car is turned off to return to the down position. fans need power to keep cooling if the thermostat calls for it after parking.
BAAAAAAHHHP (that's the wrong buzzer).
It's actually backwards and while no one can account for someone elses logic, I'll bet they were deemed devices not required to start the engine. Your key should provide:
ACC: ACC circuits only
OFF: None from key (Only circuits powered by battery have power)
ON: ACC and ON circuits
START: Starting signal to solenoid and ON circuits
This is how your switch should work and it removes power to switched circuits not required to start the car or who may draw battery current away from the starter motor (items like headlights, horn, and brake lights are powered directly from the battery). Fan and wipers are not required to start the engine or for safety.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
