Old 10-05-2011, 08:12 AM
BBQCYCLEWERKES BBQCYCLEWERKES is offline
Cobra Make, Engine: 2007 BDR FR Boss 302
I was looking at the Pro Comp roller rocker set up last year for my FE. I did some research and found them to be less then the quality I wanted. I ended up going with the PRW set up in my motor and running a .570 lift hyd. roller cam set up. Good luck with the Pro Comp set up. It costs much more then the $200 extra expense for the PRW set up if the Pro Comp system fails.
