Old 10-05-2011, 06:46 PM
2Torqued's Avatar
2Torqued 2Torqued is offline
Cobra Make, Engine: SPF MKIII, Roush 427RRRR
On 2816 i found that the splines on the back of the hub would bottom out before the proper torque was applied to the bearings. we machined out about .040 of the splins in the back of the hub so that the assembly would tighten up correctly. without doing this the bearings never received the right preload and would start to separate and loosen up in the housing.
In the picture you can see the counter bore. Once we did this not any more wheel bearing problems.
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you finally have enough horsepower". Mark Donohue
