Old 10-06-2011, 12:48 PM
BT SNAKE's Avatar
BT SNAKE BT SNAKE is offline
Cobra Make, Engine: Midstates Cobra, RFGT40
Question HELP ! This problem is driving me *#%~:nuts!
Here's the situation, I have a SBF with EFI. I can't get it to fire.
I have double checked the timing, the electrical and the fuel
All seem good. When the key is switched on the fuel pump runs for a short time then quits. I assume it has pressured up and ready to go. I have a spark lite hooked up to #1 and it indicates a very strong fire. It just will not hit a lick when cranked. I unhooked the gas line and turned the key on and plenty of fuel pumps out. So my question is... Does the injectors require a certain amount of pressure before they fire? And is it possible the pump can still pump but not up to the recommended pressure for the injectors
I have replaced the battery, cables, and checked all the fuses.
Any help is appreciated.
Hersh
