Originally Posted by BT SNAKE
When the key is switched on the fuel pump runs for a short time then quits.
I unhooked the gas line and turned the key on and plenty of fuel pumps out.
Hersh
So it pumps with the key on, does it pump when in the start position? Are you running a bypass regulator? I would get a gauge on it and verify there is correct pressure.
