Old 10-06-2011, 03:55 PM
Zedn's Avatar
Zedn Zedn is offline
Originally Posted by Ralphy View Post
Liam forces do go both ways, however considering rear brakes at best offer 25% of your braking force vs. acceleration at 100% rear. Plus the rear unloading during braking there is no comparison. I also wondered if you were to add front coilovers. In your pics I see no upper mount.
Its hard to see in the pics, but the upper brackets have a similar bracket on the other side of the RHS with the bolts going right through in double shear.
David, something else that needs to be considered is that the original jag cage is mounted on rubber bushes, so the trailing arms in the stock set up probably stabalise the cage more than they support the control arms.
