Old 10-07-2011, 06:47 AM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
I have the short input shaft tko600, QT b/h, and FE style fork with the same pivot set up, and hydraulic slave push set up, but it is installed on a SBF. When I first installed it and was testing the set up, I noticed that I could not move the fork by hand far enough to engage the pressure plate properly. Turned out that the back of the fork was interfering with the back flange of the t/o bearing, causing it to jam. I removed it and ground the back of the fork to provide reliefs for the bearing flange. That fixed it. Not sure if this is your issue Arnaud, but I figured I would share anyway!
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
