Old 10-07-2011, 07:23 AM
Avmaviator's Avatar
Avmaviator Avmaviator is offline
Cobra Make, Engine: Kirkham #647 brushed
Originally Posted by mreid View Post
Without the spacer, my fork rests on the rear flange of the bh, so that's not an option. Also, elmariachi says you should be able to see the bolts. Not on mine or it appears on the picture posted by Brent. If I try to reverse it, there is no way it will fit as the crotch of the fork rides on the tranny shaft.
Yeah I tried to mount the bracket in the two different directions. In one direction the fork hits the tranny shaft like you mentioned. In the other direction it hits the pressure plate casing. Damned either way haha.
BTW, I like the mod to the fork end so you can put a pivoting arm in there. Did you do that?
