Old 10-07-2011, 11:45 AM
2Torqued's Avatar
2Torqued 2Torqued is offline
Cobra Make, Engine: SPF MKIII, Roush 427RRRR
have your shop slide the hub on the spline and check the distance between the two surfaces and then check that measurement to the stack of bearings. The bearings should be larger than the gap in the hub assembly. As to the washer, I don't think mine had a washer ether .
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you finally have enough horsepower". Mark Donohue
