Old 10-08-2011, 02:25 PM
428 Cobra Jet's Avatar
428 Cobra Jet 428 Cobra Jet is offline
Default Vipek V88 ECU for sale (Sequential Injection)
Guy's,
I have a V88 that was installed for 2 days on a 427 Big Block FE, it was for the bases of a Tech Article for Australian Mustang and Fords.
Computer Serial Number 10493, Price $2,000, (includes, Mounting Plate, Temp sensor, Air speed sensor, Printed Manual with Wiring diagrams and Connection cable)
I also have a custom alloy plate with a 275ml surge tank mounted with a Billet 30 micron filter feeding to a Bosch 044 fuel pump connected to a Aeroflow Billet fuel pressure regulator, including all dash 6 fittings. (This unit fits up in the rear wheelwell area, using 2 x nutsert mounting bolts, very tidy) Price $400.00 (less than a tank of fuel through system).
LSI coil and mount, TPS, Lipstick style Hall effect unit, Fuel Injection engine wiring harness with wearther pak connectors, Price 400.00
8 x 550cc@30lb / 660@60lb Performance Injectors $400.00
or $2200 for the lot.
Car was weber inducted and new owner wants webers.
Darryl
What's behind is Loosing!!!! Ha Ha
