Old 10-09-2011, 07:57 AM
BT SNAKE's Avatar
BT SNAKE BT SNAKE is offline
Cobra Make, Engine: Midstates Cobra, RFGT40
If it's stabling but running most likely it's a fuel problem.
Do you smell gas while it's running? If so, then I think you popped
A power valve. Check your vacuum at idle then buy the appropriate valve for the recommended application. Go tO the holly site for more info.
Hersh
