10-09-2011, 11:38 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by RICK LAKE
Ant have been running an old 6al for 14 years. I do have spare boxes, caps, rotors, and distributors. Gears and pins too. If you are looking for a better box, look in your back yard, The company is ICE. Guys are using them on the engine master challenge and they say they make more power and last long than MSD. There system is about $200.00 more than MSD. I think the biggest problems with MSD is guys not putting the correct parts together. They do work but have failures. The only issues I have been through are burning the pile out of the cap (2 times) It's carbon. What dope thought this up instead of running metal??? I run .050" gap on plugs, 8mm plug wires with separators, HVC "e"coil. I zapped myself over the car a couple of times.  Taste like you are sucking on batterys for a couple of days and my hair is now silver.   I also don't like oil filled coils on the motor or a vibrating part of the car. It's not correct but mounted to the inside of the fender with a ground wire to the coil mount. having a good air flow around it also. Good luck Rick L.
Why ground the coil mount? I've just installed my MSD Blaster coil on the fiberglass firewall/bulkhead and I did not run a seperate ground to the coil mount. How important is this ground and what is the purpose of it?
Would much appreciate the advice as I'm in the process of finishing my wiring harness and all connections.
Thanks, Arthur
